> ## Documentation Index
# Preview Manual Signal Scan
> Check for completed sessions before submitting a manual Signal scan.
## OpenAPI
````yaml https://api.galileo.ai/public/v2/openapi.json get /v2/projects/{project_id}/runs/{run_id}/signals/scans/preview
openapi: 3.1.0
info:
  title: FastAPI
  version: 0.1.0
servers:
  - url: https://api.galileo.ai
    description: Galileo Public APIs - galileo-v2
security: []
paths:
  /v2/projects/{project_id}/runs/{run_id}/signals/scans/preview:
    get:
      tags:
        - signals-v2
      summary: Preview Manual Signal Scan
      description: Check for completed sessions before submitting a manual Signal scan.
      operationId: >-
        preview_manual_signal_scan_v2_projects__project_id__runs__run_id__signals_scans_preview_get
      parameters:
        - name: project_id
          in: path
          required: true
          schema:
            type: string
            format: uuid4
            title: Project Id
        - name: run_id
          in: path
          required: true
          schema:
            type: string
            format: uuid4
            title: Run Id
        - name: window_start
          in: query
          required: true
          schema:
            type: string
            format: date-time
            title: Window Start
        - name: window_end
          in: query
          required: true
          schema:
            type: string
            format: date-time
            title: Window End
      responses:
        '200':
          description: Successful Response
          content:
            application/json:
              schema:
                $ref: '#/components/schemas/SignalScanPreviewResponse'
        '422':
          description: Validation Error
          content:
            application/json:
              schema:
                $ref: '#/components/schemas/HTTPValidationError'
      security:
        - APIKeyHeader: []
        - ClassicAPIKeyHeader: []
        - OAuth2PasswordBearer: []
        - HTTPBasic: []
components:
  schemas:
    SignalScanPreviewResponse:
      properties:
        data:
          $ref: '#/components/schemas/SignalScanPreview'
      additionalProperties: false
      type: object
      required:
        - data
      title: SignalScanPreviewResponse
    HTTPValidationError:
      properties:
        detail:
          items:
            $ref: '#/components/schemas/ValidationError'
          type: array
          title: Detail
      type: object
      title: HTTPValidationError
    SignalScanPreview:
      properties:
        has_eligible_sessions:
          type: boolean
          title: Has Eligible Sessions
      type: object
      required:
        - has_eligible_sessions
    ValidationError:
      properties:
        loc:
          items:
            anyOf:
              - type: string
              - type: integer
          type: array
          title: Location
        msg:
          type: string
          title: Message
        type:
          type: string
          title: Error Type
        input:
          title: Input
        ctx:
          type: object
          title: Context
      type: object
      required:
        - loc
        - msg
        - type
      title: ValidationError
  securitySchemes:
    APIKeyHeader:
      type: apiKey
      in: header
      type: apiKey
      in: header
      type: oauth2
      flows:
        password:
          scopes: {}
          tokenUrl: https://api.galileo.ai/login
    HTTPBasic:
      type: http
      scheme: basic
This documentation is built and hosted on [Mintlify](https://mintlify.com), a developer documentation platform.
