> ## Documentation Index
# Fixing Hallucinations and Factual Errors
> Learn how to identify and address hallucinations and factual errors in your AI models
Hallucinations occur when an AI model generates factually incorrect information that is not grounded in any real-world knowledge. These are sometimes called "open-domain factual errors" and can significantly impact the reliability of your AI system. In this particular guide, we're going to focus on hallucinations that have to do with "open-domain" facts - as opposed to hallucinations that have to do with "closed-domain" facts, which are more common in the context of RAG systems.
## Setup
Consider the following prompt:
```text theme={null}
Which are better: Sharks or Tigers? Explain why.
Answer succinctly, you must choose one.
And the following response:
<Card>
  Tigers are better because they are apex predators with a versatile skill set, capable of thriving in diverse terrestrial environments, whereas sharks are specialized for aquatic life. Tigers have complex social behaviors and are more adaptable to a range of habitats compared to sharks.
</Card>
As we can see, the model cites a number of facts about sharks and tigers. While they are individually correct, the response as a whole also claims that these facts prove that tigers are better than sharks. This is a subjective statement, and the model has no way to know whether this is true or not.
### What went wrong?
Let's look at the explanation:
<Card>
  **The response has a 66.67% chance of being factually correct.**
  The response makes several claims regarding why tigers are better than sharks:
  1. **Tigers are apex predators:** This claim is factually correct as tigers are considered apex predators in their terrestrial habitats, primarily preying on larger herbivores.
  2. **Tigers have a versatile skill set and can thrive in diverse terrestrial environments:** This claim is true as tigers can adapt to various habitats, including forests, grasslands, and swamps, showcasing their versatility in hunting and survival skills.
  3. **Sharks are specialized for aquatic life:** This claim is also correct. Sharks have evolved as top predators in marine environments, having physical adaptations, such as streamlined bodies and gills, making them highly effective in water.
  4. **Tigers have complex social behaviors and are more adaptable to a range of habitats than sharks:** While it is true that tigers display some level of social interaction, such as mother-cub relationships, they are generally solitary animals. The adaptability claim is partially accurate; however, it should be noted that sharks are well adapted to their own environments, but they are not adaptable to land environments due to their physiological needs.
  Overall, while the response presents some correct information about both species, the assertion that tigers are 'better' than sharks is subjective and lacks a definitive basis since 'better' can depend on context and criteria. In terms of factual correctness, the claims made do not fundamentally present falsehoods but the comparison drawn lacks a nuanced view of the strengths of both animals.
</Card>
As the explanation suggests, the root cause of open-domain hallucination are quite often due to ambiguity in the prompt, lack of constraints on the response, lack of context - or a combination of these factors.
When models hallucinate, it's typically due to one or more of these issues:
* **No constraints on responses**: The model wasn't instructed to limit responses to known facts
* **Allowed speculation**: The model was permitted to make claims without verification
* **Lack of validation**: No post-processing was implemented to validate factual correctness
### How it appears in evaluators
Hallucinations typically manifest in evaluators as:
* **Low Correctness scores**: Responses contain factual inaccuracies
## Solutions to prevent hallucinations
<Steps>
  <Step title="Explicitly Instruct the Model to Avoid Guessing">
    Modify your prompts to discourage speculation:
    Instruction: Only provide answers that are scientifically verified.
    If you're unsure about something, say 'I don't know' rather
    than guessing.
    **Implementation tips:**
    * Add explicit uncertainty instructions to your system prompt
    * Include examples of good "I don't know" responses in few-shot prompts
    * Reward the model for admitting uncertainty rather than making up answers
    * Consider phrases like "It's important to be accurate rather than comprehensive"
  </Step>
  <Step title="Add Response Validation">
    * Implement automated validation using Correctness scores
    * Flag responses with a low Ground Truth Adherence score for human review
    * Consider using retrieval-augmented generation (RAG) to ground responses in verified sources
    **Validation techniques:**
    * Use Splunk Agent Observability's Ground Truth Adherence evaluator to compare responses against known facts
    * Implement confidence thresholds where low-confidence answers trigger fallback responses
    * For critical applications, create a verification pipeline with multiple checks
    * Consider a "cited response only" approach where all factual claims must reference sources
  </Step>
  <Step title="Implement Post-Processing Checks">
    * Run additional LLM-based checks for factual accuracy before serving responses
    * Filter out responses that exceed an uncertainty threshold
    * Consider implementing a citation system for factual claims
    **Advanced verification methods:**
    * Create a separate "fact-checking" LLM call that evaluates the main response
    * Implement a multi-agent approach where one agent generates and another verifies
    * Use structured output formats that separate facts from opinions/interpretations
    * For high-stakes domains, maintain a database of verified facts to check against
  </Step>
  <Step title="Design for Transparency">
    * Clearly communicate the model's limitations to users
    * Provide confidence scores alongside responses
    * Distinguish between factual statements and opinions/interpretations
    * Consider visual indicators for different levels of certainty
    **User experience considerations:**
    * Use UI elements like confidence meters or color-coding for certainty levels
    * Provide "View Sources" options for factual claims
    * Design graceful fallbacks when the model is uncertain
    * Consider allowing users to provide feedback on factual accuracy
  </Step>
  <Step title="Monitor and Continuously Improve">
    * Use Splunk Agent Observability to track hallucination rates over time
    * Collect examples of hallucinations to create targeted test cases
    * Regularly audit responses, especially for high-risk domains
    * Implement feedback loops to improve the system based on real-world performance
    **Monitoring strategy:**
    * Set up custom evaluators in Splunk Agent Observability specifically for tracking hallucination types
    * Create a "hallucination dataset" of challenging examples for regression testing
    * Implement user feedback mechanisms to flag potential hallucinations
    * Schedule regular reviews of flagged responses to identify patterns
  </Step>
</Steps>
## Best practices
<CardGroup cols={2}>
  <Card title="Layer your defenses" icon="shield-halved">
    Combine multiple approaches rather than relying on a single method. Use a combination of prompt engineering, validation, and post-processing checks.
  </Card>
  <Card title="Domain-specific knowledge" icon="book">
    For specialized domains, create custom knowledge bases or retrieval systems that contain verified information relevant to your application.
  </Card>
  <Card title="Calibrate confidence" icon="gauge-high">
    Train your system to accurately represent its confidence level. Models should express appropriate uncertainty when dealing with ambiguous or incomplete information.
  </Card>
  <Card title="Progressive disclosure" icon="layer-group">
    Consider revealing information in stages, with increasing verification for more detailed claims. Start with high-confidence facts before providing specifics.
  </Card>
  <Card title="Continuous evaluation" icon="magnifying-glass-chart">
    Regularly test your system against new examples of potential hallucinations. Build a test suite of challenging cases that target known weaknesses.
  </Card>
  <Card title="Human-in-the-loop" icon="user-check">
    For critical applications, maintain human oversight for final verification. Design workflows where humans can efficiently review and correct model outputs.
  </Card>
  <Card title="Feedback integration" icon="arrows-spin">
    Create mechanisms to learn from identified hallucinations. Use feedback loops to continuously improve your system's factual accuracy over time.
  </Card>
  <Card title="Contextual awareness" icon="scale-balanced">
    Adjust verification stringency based on the stakes of the interaction. Apply more rigorous checks for high-risk domains like healthcare or finance.
  </Card>
</CardGroup>
