Overview
This tutorial will guide you through initializing the Splunk Agent Observability Logger and Agent Control SDK, running your agent with the Splunk Agent Observability Logger, and decorating your LLM and tool calls. By the end of this guide, you’ll be ready to start monitoring your controls.Before you begin
This tutorial assumes you have completed the following procedures:Steps
1
Set the required environment variables
For more information on these environment variables, see Configuration.
Set
AGENT_CONTROL_RUNTIME_TOKEN_HEADER to the header name that carries the runtime token (for example X-Agent-Control-Runtime-Token) and use Agent Control SDK 8.5.0 or later. With this configuration, the SDK sends the runtime token in that header as a raw token without a Bearer prefix. Authorization remains reserved for gateway authentication.2
Initialize the Splunk Agent Observability Logger and the Agent Control SDK
Use the Splunk Agent Observability Logger around the agent run to write traces, spans, and control spans to the configured project and Agent Stream. The exact logger API may differ depending on your SDK version. You must initialize Splunk Agent Observability with the same project and Agent Stream that you plan to create controls for.The following example shows how to initialize the Splunk Agent Observability Logger.Note that:
- The value for
target_idshould belogger.agent_stream_id, not the Agent Stream name. The logger resolves the human-readable project and Agent Stream names to IDs, and Agent Control uses that resolvedagent_stream_idto fetch the controls. - You must use the same API key unless your deployment has a separate Agent Control key. The key must be valid for your targeted Splunk Agent Observability environment.
3
Run your agent with the Splunk Agent Observability Logger
4
Decorate your LLM and tool calls
Wrap LLM and tool Steps with the SDK decorator so controls can evaluate the right Steps. Use For tool call examples and more details, see Decorate LLM and tool calls.
@control() on the function that performs the LLM call.
